Troubleshooting the Core Antispam Engine
To ensure that the Core Antispam Engine functions properly, the exceptions listed under Configuring installed on-access virus scanners must be set. If problems still occur, check the following points one after the other:
- Are there up-to-date definitions on the Gateway Role system? The path is C:\ProgramData\Net at Work Mail Gateway\Core Antispam Engine\antimalware\1\.
- If the definitions are up to date, it may be useful to activate the engine logging. To do this, add the following lines to the file C:\ProgramData\Net at Work Mail Gateway\Core Antispam Engine\bdamserver.conf:
LogAppend=1
LogDebug=1
The logs created in this way in the directory C:\ProgramData\Net at Work Mail Gateway\Core Antispam Engine\Logs can then be sent together with the message tracks of affected emails to your reseller or directly to NoSpamProxy support for clarification.
