Offline installation
If you want to run the setup file on a computer that has no or only limited access to the Internet, proceed as follows:
- Switch to a computer that can access the Internet. This can also be a computer with a client operating system.
- Download the setup file to this computer or place the file on this computer.
- Open the command line and enter the following command:NameOfTheSetupFile.exe /layoutKommandozeile
- Specify the download path.
- After the download is complete, copy the folder with the downloaded files to the computer on which you want to install NoSpamProxy.
- Run the Bundle.exe file.
