Upgrades
General Information
If you are updating from a previous version of the Web Portal, please note the following.
  • In most cases of an update you will have to perform manual steps before and after the installation, otherwise the smooth operation of the Web Portal is no longer guaranteed. Please refer to the notes under Upgrade paths. The sections are cumulative, which means that you must follow the sections from your currently installed version to the current version in sequence.
  • In any case, check the configuration of your Web Portal after you have carried out a program update.
Upgrade paths
Updates from version 13.1 to version 13.2
When updating from version 13.1 to version 13.2, all settings and user information are retained during the update.
Updates from version 13 to version 13.1
When updating from version 13 to version 13.1, all settings and user information are retained during the update.
Updates from version 12.2 to version 13
When updating from version 12.2 to version 13, all settings and user information are retained during the update.
Updates from version 12.1 to version 12.2
When updating from version 12.1 to version 12.2, all settings and user information are retained during the update.
Updates from version 12 to version 12.1
When updating from version 11.1 to version 12, all settings and user information are retained during the update.
Updates from version 11.1 to version 12
Updates from version 11 to version 11.1
With version 11.1, the SQL Server version 2008 is required. Please update your SQL Server 2005 to at least version 2008 before you start the NoSpamProxy Update. When updating from version 11 to version 11.1, all settings and user information are retained during the update.
Updates from version 10.1 to version 11
When updating from version 10.1 to version 11, all settings and user information are retained during the update.
Updates from version 10 to version 10.1
When updating from version 10 to version 10.1, all settings and user information are retained during the update.
