D-Trust
  1. Go to Identities > Key enrolment > Key enrolment provider.
  2. Click Add.
  3. Select D-Trust as the provider.
  4. Enter the name of the certificate template and the operator address. You can obtain both information from D-Trust.
    NOTE: The operator address is the email address that is used to handle requests. This address is used as the sending address for all requests and must be reachable.
    NOTE:
    The following certificate templates are supported:
    • ADVANCED_PERSONAL_ID_1
    • ADVANCED_PERSONAL_ID_2
    • ADVANCED_ENTERPRISE_ID_1
    • ADVANCED_ENTERPRISE_ID_2
    • ADVANCED_TEAM_ID_1
    • ADVANCED_TEAM_ID_2
  5. Determine whether you want to publish your key to Open Keys. See Using Open Keys.
  6. Click Finish.
NOTE: In order to use D-Trust as a provider, you must have concluded a valid contract with Deutsche Bundesdruckerei and imported the D-Trust certificate int the certificate administration.
See
Integrating D-Trust
