GlobalSign Atlas
  1. Go to Identities > Key enrolment > Key enrolment provider.
  2. Click Add.
  3. Select GlobalSign Atlas as your provider.
  4. Enter a name for the key enrolment.
  5. Geben Sie die Zugangsdaten ein.
    NOTE: The credentials are provided by GlobalSign.
  6. Select the mTLS certificate you want to use.
  7. Select whether and which of the values of the key enrolment fields you always want to overwrite. See Automatic overwriting of values.
  8. Determine whether you want to publish your key to Open Keys. See Using Open Keys.
  9. Click Finish.
NOTE: You must enable an IP address range for the API in the profile. Only then can certificates be requested via the interface.
