SSLplus
  1. Go to Identities > Key enrolment > Key enrolment provider.
  2. Click Add.
  3. Select SSLplus as your provider.
  4. Enter a unique name and the API token you received from SSLplus and click Next.
  5. Enter the name of the CA, the name of the product and the validity and click Next.
  6. (Optional) Select whether and which of the values of the fields for the key request you always want to overwrite. If you tick the check box for city and state or area, either both fields must be filled in or both fields must be empty.
  7. Determine whether you want to publish your key to Open Keys. See Using Open Keys.
  8. Click Next and then Finish.
