Step 3: Sending the system certificate to D-Trust
- Open the Certificate Service Manager.
- Go to Startseite > Kontoverwaltung > Benutzer > Systeme .
- Click Neu.
- Enter an internal name for the system.
- Perform one of the following two steps:
- Click Datei auswählen and upload the request.csr file.
- Copy the contents of the file request.csr from the clipboard into the green input field.
- Click Anlegen.
NOTE: The certificate is now being processed. The corresponding PIN will be sent to you by post.
TIP: You can check the status of your access token under Startseite > Einstellungen > Meine Zugangstoken.
Next steps
