Step 1: Activating the AS4 module
To set up AS4 market communication, you must activate the relevant components before installing NoSpamProxy. Otherwise they will not be displayed during installation.
Execute the following command line parameter in the directory in which the NoSpamProxy installation file is located:
setup.exe /EDI@Energy=1
The NoSpamProxy installation will now start. During installation, make sure that select the components
EDI@Energy and
Key management
during setup.
