DigiCert
- Go to Identities > Key enrolment > Key enrolment provider.
- Click Add.
- Select DigiCert as your provider.
- Enter a unique name and the API key you received from DigiCert and click Next.
NOTE: Make sure that the API key is restricted to Orders, Domains, Organizations. We advise against configuring the restriction No restriction.
NOTE: The API key must be assigned to a user who is allowed to view organisations, i.e. either Administrator (unrestricted) or Manager (unrestricted).
- Select the product, the organisation and the validity of the key and click Next.
- Enter a prefix if you want to request a pseudonymised certificate. Alternatively, select one of the default values pseudonym or pseudo.
- Determine whether you want to publish your key to Open Keys. See Using Open Keys.
- Click Finish.
NoSpamProxy supports the DigiSign certificates Secure Email for Business and the Premium client certificates.
NOTE: From version 15.5, you must create a separate AD group for system mailboxes, for example info@example.com or and support@example.com. Under Automatic key enrolment in the group settings, you must then select the option Use pseudonym prefix for requests. See Automating the user import.
