GlobalSign (legacy)
- Go to Identities > Key enrolment > Key enrolment provider.
- Click Add.
- Select GlobalSign (legacy) as the provider.
- Enter the credentials you have received from GlobalSign.
NOTE: Once you have registered with GlobalSign you will receive the login details for the GlobalSign Management Portal. You enter these access data in the GlobalSign configuration dialog. In the portal you can also configure profiles and purchase certificate packages. You also enter this data here.
- Enter a prefix if you want to request a pseudonymised certificate. Alternatively, select one of the default values pseudonym or pseudo.
- Determine whether you want to publish your key to Open Keys. See Using Open Keys.
- Click Finish.
NOTE: You must enable an IP address range for the API in the profile. Only then can certificates be requested via the interface.
TIP: For security reasons, GlobalSign limits the API to certain request IP addresses. In order for your requests to be successful, you must deposit the public IP addresses of your gateway roles with GlobalSign.![]()
NOTE: From version 15.5, you must create a separate AD group for system mailboxes, for example info@example.com or and support@example.com. Under Automatic key enrolment in the group settings, you must then select the option Use pseudonym prefix for requests. See Automating the user import.
