Outlook Add-in is deactivated due to long loading times
In some cases the NoSpamProxy Outlook Add-In is deactivated because of long loading times. This article describes procedures on how to change this.
Reduce loading times
If you have installed a local virus scanner on the client system, you should exclude the real-time scan for the following directory:
C:\Users\<<Username of the logged in account>>>AppData\Local\Assembly
In this directory are the DLL files for the Add-In, but they change with every update. The entire directory should therefore be excluded from the real-time scan
Prevent deactivation despite long charging time
You can change the Load Behavior for the Add-In - ideally to Load Behavior = 3 in the Registry.
Further information
Registry PathHKEY_CURRENT_USER \ SOFTWARE \ Microsoft \ Office \ Outlook \ Addins \Netatwork.MailGateway.OutlookAddIn
MS Technet Article https://msdn.microsoft.com/en-us/library/bb386106.aspx#LoadBehavior
