D-Trust
- Go to Identities > Key enrolment > Key enrolment provider.
- Click Add.
- Select D-Trust as the provider.
- Enter the name of the certificate template and the operator address. You can obtain both information from D-Trust.
NOTE: The operator address is the email address that is used to handle requests. This address is used as the sending address for all requests and must be reachable.
NOTE:The following certificate templates are supported:
- ADVANCED_PERSONAL_ID_1
- ADVANCED_PERSONAL_ID_2
- ADVANCED_ENTERPRISE_ID_1
- ADVANCED_ENTERPRISE_ID_2
- ADVANCED_TEAM_ID_1
- ADVANCED_TEAM_ID_2
- Enter a prefix if you want to request a pseudonymised certificate. Alternatively, select one of the default values pseudonym or pseudo.
- Determine whether you want to publish your key to Open Keys. See Using Open Keys.
- Click Finish.
NOTE: In order to use D-Trust as a provider, you must have concluded a valid contract with Deutsche Bundesdruckerei and imported the D-Trust certificate int the certificate administration.
