Integrating D-Trust
The following hardware and software is required to use D-Trust certificates in NoSpamProxy Encryption:
- Smartcard
- Card reader
- PIN
- neXus Personal Desktop
- OpenSSL
NOTE: The certificate that is stored on the smart card cannot be exported or used directly in NoSpamProxy. It is only used for authentication as operator on the web interface. You then use the certificate to generate a system certificate that is stored in NoSpamProxy to use the connector.
NOTE: OpenSSL is included in Linux operating systems by default. An installer file for free installation of OpenSSL on Windows can be found at http://slproweb.com/products/Win32OpenSSL.html .
Next steps
If all prerequisites are met, continue with the following steps:
Step 1: Browser settings (Firefox)
Step 2: Creating a system certificate
Step 3: Sending the system certificate to D-Trust
Step 4: Creating the key material
Step 5: Integrating D-Trust into NoSpamProxy
