GlobalSign Atlas
- Go to Identities > Key enrolment > Key enrolment provider.
- Click Add.
- Select GlobalSign Atlas as your provider.
- Enter a name for the key enrolment.
- Enter the access data.
NOTE: The credentials are provided by GlobalSign.
- Select the mTLS certificate you want to use.
- Select whether and which of the values of the key enrolment fields you always want to overwrite. See Automatic overwriting of values.
- Enter a prefix if you want to request a pseudonymised certificate. Alternatively, select one of the default values pseudonym or pseudo.
- Determine whether you want to publish your key to Open Keys. See Using Open Keys.
- Click Finish.
NOTE: You must enable an IP address range for the API in the profile. Only then can certificates be requested via the interface.
NOTE: From version 15.5, you must create a separate AD group for system mailboxes, for example info@example.com or and support@example.com. Under Automatic key enrolment in the group settings, you must then select the option Use pseudonym prefix for requests. See Automating the user import.
