What information is required for the initial analysis?
Please provide the following information to support:
  • Version of the NoSpamProxy installation. You can find this in the top right-hand corner of the NoSpamProxy Command Center homepage.
Description of the problem Brief description of the problem and how it manifests itself:
  • Recent Issues on the homepage.
  • Any warnings and/or errors that occurred at the time of the problem can be viewed in the NoSpamProxy Command Center under Monitoring > Event log.
  • Details of message tracking. If there are any delivery issues, they can be exported as follows:
    1. Go to Monitoring > Message tracking.
    2. Double-click the relevant entry.
    3. In the new window, click Export message track.
    4. Save the JSON file.
  • Information from Monitoring > Email Queues and/or Monitoring > E-Mails on hold in the NoSpamProxy Command Center.
  • Any other information and/or screenshots that describe the problem.
  • Update Logs, where update issues are concerned.
