Known errors
- Reply links are not inserted into emails
- The DNS server is blocked by a Spam URI Realtime Blocklist
- The revocation status of a certificate cannot be retrieved
- The Intranet Role does not launch under TLS 1.2
- The NoSpamProxy Command Center cannot connect to the Intranet Role
- Services do not start because binding on http://+6060/nospamproxy does not work
- D-Trust error: Failed to enroll for the certificate. Error: Rejection
- Emails are not sent from the Outlook inbox unless Send immediately is set
- Emails are rejected with a Base64 error
- Missing Large-Files or De-Mail settings after Windows updates
- Error ASN1 - Not enough memory
- Error The email could not be decrypted because the encrypted data is corrupted
- Error message 5.7.51 TenantInboundAttribution
- Error message Unable to relay
- Error The security protocol cannot verify the incoming message
- Content in the NoSpamProxy Command Center (NCC) cannot be displayed for certain users
- Locally signed emails are permanently rejected due to faulty S/MIME signatures
- Why are both my inbound and outbound emails rejected with "Mailbox unavailable"?
- Message displayed Message delivered via relay
- NoSpamProxy setup fails during installation of PowerShell RemoteWIN
- Outlook Add-in is deactivated due to long loading times
- Smartcards over remote USB connections do not work
- The event viewer repeatedly displays Warning 1088
- Certificate retrieval at SwissSign fails with "The request was aborted: Could not create SSL/TLS secure channel
- Error "4.7.4 The TLS configuration on the server is incomplete or faulty."
- Meldung 4.1.0 Please try again in a new SMTP session
